ac compressor
Old Mar 29, 2011 | 01:56 PM
jimp00's Avatar
Default ac compressor
My mc has a smaller pulley on it than it should have will this effect the preformance of my engine.Will I have to replace the whole unit or can I just change the pulley and clutch.Thanks for help
Old Mar 29, 2011 | 07:41 PM
Justin Knight's Avatar
depending on the year of your car, the a/c compressor is a 5 piston variable displacement style and a smaller pulley in theory should work just fine. it will only produce as much pressure as it needs to. as for the rest of the car, i'd try it out because replacing the clutch and pulley usually wrecks the compressor shaft. as long as the belt is still the correct size and has free room to self adjust under load i would think it should be okay.
Old Mar 29, 2011 | 11:40 PM
jimp00's Avatar
Thanks justin the only thing that I have noticed is the rest of the pulleys are for a 6 grove belt so it tore one groove off before I found the problem.Its a 2000 mc ss 3800.That was a expensive lesson. I was told just to run it with the belt with the groove gone not real comfortable with that.
motivation2k3
Sep 29, 2008 03:58 PM
motivation2k3
Sep 29, 2008 08:22 AM
smolek37k
Aug 6, 2008 08:36 AM
nitehwk10
Apr 26, 2008 02:46 PM
SophicSage
Jul 24, 2005 03:29 PM
