need help '00 MC not starting properly
Old Mar 30, 2011 | 12:14 PM
Derbking7's Avatar
Default need help '00 MC not starting properly
hey guys. I have a 2000 Monte Carlo LS (3.4L). Recently its had some trouble starting. I turn the key and the engine sounds like it starts but immediately dies. If I give it just a little gas while trying to start it the engine will start, and rev high but eventually settle down to normal.
I had a check engine light and pulled the code. It was P1404 which said "EGR Closed Position Performance." I went and bought a new EGR valve and installed it. Same issue. Took it to a NTB shop and the tech said that the valve I had was either bad or the wrong model (the one i bought was from autozone and model EGR1147). I took the valve back today, and got a new one with the same issue.
Anybody got any ideas as to what the issue could be? I cleaned the MAF before I pulled the code thinking maybe that was it, and I also changed the throttle position sensor thinking maybe I had a dead spot in the potentiometer.
Thanks for any and all help and advice in advance.
Old Mar 30, 2011 | 12:18 PM
One more sensor on the TB you missed. The IAC.
When you need to give it gas to start sounds like that's the issue.
Old Mar 30, 2011 | 01:31 PM
Derbking7's Avatar
you were 100% correct! i just put in a new IAC and she started up beautifully!
thank you very very very very much!
Old Mar 30, 2011 | 02:17 PM
You're very welcome!
blackmonte781
Sep 14, 2011 08:46 PM
FakeAccident06
Feb 19, 2010 03:55 PM
cmeadows06
Jun 18, 2009 02:44 PM
XM_JDM
Feb 19, 2009 12:50 PM
golfstud2k4
Jan 8, 2007 04:10 AM
