99 monte carlo tune up please help
Old May 20, 2010 | 07:16 AM
NINJAJUGGALO18's Avatar
Default 99 monte carlo tune up please help
ok i got the front 3 plugs done the back 3 i cannot get i did the wish bone took em off got engine to move like a inch its been 5 years since a tune up has been done i was able to fell one of the plugs wires pullled on it will not budge tryed turnin it wont turn eather they wont come off ( the wires) front i had a problem to but i got the front done any idea how i can get to these back 3 and get wires off please help plain to try agin in about hour or 2 hours it is a 99 monte carlo 3.1 sohc
not real sure if i might of done nything wrong why im askin and is it bad to drive with the 3 front good plugs and wired and the 3 being bad thanks in advance
ps new to threds 1st post
Old May 20, 2010 | 08:48 AM
Welcome to the MCF
Sorry that you are having problems getting to your back 3 plugs.
Check back on your thread question & also use our search
engine to explore for a answer.
Also read the below....Good Luck
Answer
a garage to get plugs replaced, and they said that it is very difficult and wanted to charge me $300.00 Dollars. All I ended up doing was removing that top Pillum. Now this is tricky because you cant reach the bolt on the drivers side to remove it, unless you take the air conditing stuff off. But i welded a bolt to my wrench and was able to get the bolt off. It saved me alot of time.
Answer
The Most common way to get the rear 3 plugs is to release the (dog bone)front motor mounts and just roll the car foward and the engine will tilt foward about 6 inches and makes it a lil easier to get the plugs. you can do as the above person said about the dog bone but i just use the size rachet needed with a extender to unlosen the spark plugs then i use a small rubber hose and stick it down around the plug and twist it a little then slowly pull it up and remove it.
Old May 20, 2010 | 08:57 AM
You may have to cut your loss and get new wires too and just cut the old wires off to get to the plugs
chevyONmine
Aug 1, 2023 07:33 AM
07ss_ls4
13
May 9, 2014 12:17 PM
Dam20735
Aug 18, 2012 07:01 PM
robertlm12
Feb 11, 2012 02:35 PM
Cowboy6622
16
Aug 12, 2008 08:59 PM
