clunking noise
Old May 19, 2010 | 03:03 AM
02montecarlo's Avatar
Default clunking noise
Hi I have an 02 ss and there seems to be one clunking noise coming from my steering colum..any ideas?
Old May 19, 2010 | 05:17 AM
los83's Avatar
Intermediate Steering Shaft needs grease.
https://montecarloforum.com/forum/monte-carlo-repair-help-8/iss-repair-2257/
I did it this way, much easier!
http://www.naioa.com/v2/modules.php?...&highlight=iss
Peace out.
Old May 19, 2010 | 07:49 AM
MAMONTE's Avatar
Yep follow the above links, and you will be able to fix the problem.
It is definitely your ISS.
Old May 19, 2010 | 08:37 AM
I oil my ISS every spring.
Old May 19, 2010 | 10:33 AM
los83's Avatar
Kinky!!
Old May 19, 2010 | 01:37 PM
Wow thanks for the tip...this one shop wanted 580 to install a new one...so 20min n done huh. Sounds good to me. But get this the stock iss lasted 210,000miles pretty good eh?
Old May 19, 2010 | 06:31 PM
https://montecarloforum.com/forum/showthread.php?t=2257
Peace out.
So how do I get the grease in it..down behind the black thing or in that **** of it the one sticking out?
Old May 20, 2010 | 05:18 AM
los83's Avatar
Down where the tube is going. Mind you most people use lithium grease & spray it down there. I used a grease gun & synthetic grease.
The grease is thicker & takes longer to get down in there but the flip side is I won't have to get in there for a long time to maintain it.
Old May 20, 2010 | 05:26 AM
So that web page that you sent earlier in the thread was for impalas right...its the same procedure for the mc?
Old May 20, 2010 | 07:48 AM
MAMONTE's Avatar
Samething for the Monte as the Impala!
