99 elecriclal mystery
Old Feb 12, 2007 | 06:59 PM
burninvernin's Avatar
Default 99 elecriclal mystery
Hi,
I' ve owned a 1999 Montefor 2 years. The headlights, not just theDRL's stay on when ignition is on. Might not be part of the problem, I don't know. A year ago it would not start, no lights, no radio,no clicks, nothing. I turned the key on and off a couple of times and wiggled the shift lever and it started.Since than it has died a couple of times, but restarted right away,so I changed the plugs, wires, and added fuel injector cleaner. It's been fine till today. I was backing out of my driveway and it died. Itried like above to no avail. I checked the battery wires, they were tight and looked fine. I got back in the car tried like above again, samething.I had the key in the on positionthan everything came on andI was able to start it, I shut it off and samething happened. I triedlike above and added flipping the light switch on and offagain and it started. Tried spare key ( in case it was theanti-lock thing), it started both times. tried once with the primary keyand it started. I don't want to keep driving it on faith, so I want to ask someone smarter than me. Any ideas?
Update: It has ran fine since 1-5-07. Today it woud not start the door dinger sounded low on juice, so I fiddled with the battery and it started. Coincedence maybe? Because I tried to start it again and nothing. I put a battery charger on it the door dinger sounds better, butit just clicks when I try to start it. WhenI release the keyto the "on" position all thelights in the cabin flicker
Thanks, Vern [align=right][/align]
Old Feb 12, 2007 | 11:40 PM
InTheIROC's Avatar
Default RE: 99 elecriclal mystery
ORIGINAL: burninvernin
This part of it sounds like you have a bad battery... I would get the battery tested and replaced if needed as a starting point.
Old Feb 13, 2007 | 07:50 AM
Thanks for the response. I did replace the battery and it starts now, but I know that isnot the answer to it's problems
Vern.
Old Feb 13, 2007 | 09:24 PM
InTheIROC's Avatar
I don't think it was the answer to all it's problems, but it's a good place to start.
Any codes? You may have an ignition control module going bad.
Old Feb 14, 2007 | 02:10 AM
z34phoenix's Avatar
the icm wont stop power with key on....
sounds like a bad ignition switch. they have been known to fail. a failing ICM would show misfires your car just isnt starting.and not showing power when you turn the key... would make me suspect the key/lock (ignition switch)
keep us posted
Old Feb 14, 2007 | 05:40 AM
Mrrench's Avatar
I would have the starter tested as well......
Old Feb 14, 2007 | 07:55 AM
Thanks for the advise. I'll check the codes today and have the starter tested.
Vern
Old Feb 15, 2007 | 05:57 PM
I checked for codes and came up with nothing, probably because I changed the battery. I have not had the starter tested yet. I will let you know when I come up with a solution.
Thanks, Vern
Old Feb 17, 2007 | 05:40 PM
Quick question, while I'm waiting for a code. Could the ICM or ignition switch cause the headlights to stay on when the key is in the on position?
Old Feb 18, 2007 | 01:50 PM
enibum's Avatar
Is your car equipped with auto on headlights? It could be that you have something covering the sensor on the dash.
moneycarlo
Aug 19, 2008 07:22 PM
98monte
May 23, 2008 08:52 AM
GrandPaDave
Aug 29, 2007 09:34 PM
79Monte
Jan 8, 2007 04:57 AM
Mshaginaw
Jan 5, 2007 02:41 PM
