98cruise control and power door locks malfuntion
Old Apr 29, 2009 | 01:45 AM
supercharged SS's Avatar
Default 98cruise control and power door locks malfuntion
Okay so thanks for any help in advance.
So my 98 3.1 monte has cruise control but the darn thing doesnt work I dont know what to trouble shoot, i havent look at in a while but i dont think the fuze was blown. What could it be? i have the hanes manual but it wasnt of any help.
Second problem my door locks dont work i replaced the driver side switch cuz the original one didnt and i thought that was the problem but still nothing click. And btw the ODB II scanner port on my monte doesnt work properly so i feel helpless it cant seem to communicate with the snap-on scanner tool help me please
Old Apr 29, 2009 | 08:55 PM
vincenti's Avatar
you should definately check those fuses first for the cruise and confirm they're OK. as far as the power locks, do they work from the passenger side? or are both sides ka-poot. once again, fuses....
Old Apr 29, 2009 | 09:32 PM
okay will look the fuzes over and neither driver or passanger side pwl work
Old May 5, 2009 | 07:47 PM
all fuses are fine what should i look at next
Old May 8, 2009 | 03:48 AM
vincenti's Avatar
did your cruise control/ power lock trouble start at the same time? about the same time you replaced that switch? if so, you may have ground trouble. believe it or not, one bad ground in one place can affect several electrical components. I had an S-10 that didn't have the headlight plug all the way attached and as a result I had BOTH headlights go extremely dim/ high beam indicator wouldn't work properly/ emergency lights went highwire/ ect. once I secured that plug everything was A-OK.
Old May 19, 2009 | 07:46 PM
okay i'll try looking for a ground wire and look over as much as possible
03_MONTE SS
May 15, 2015 07:30 AM
zgcave
Jan 16, 2011 01:14 PM
fastback4
Oct 20, 2009 05:34 PM
whitelite
May 29, 2008 01:10 PM
alphadragon
Nov 19, 2007 06:08 PM
