6th Gen ('00-'05): Power door locks problem?? Help!
Old Apr 24, 2013 | 12:48 PM
03_MONTE SS's Avatar
Default Power door locks problem?? Help!
Hello everyone. I have a 2003 Monte SS. Every thing was fine until a few days ago. For no reason both my power door locks stopped working. I read something about alarm system or something messing it up. A red light on my radio does flash. I do have key-less entry. When i try and use the remote to unlock my headlights do come on like it received the request, but my locks do not work. The locks do not work from the inside either. I have checked the 15 A fuse under the hood its ok. I have tried disconnecting battery to reset CPU as well, still no luck. Any ideas on what to do next would be greatly appreciated. Thanks,
Old Apr 24, 2013 | 05:29 PM
xxfallen-comradexx's Avatar
Awaiting Email Confirmation
My brother had the same issue with his 04 SS. We ended up taking the door panels off and cleaning the buttons from the inside. Also do you notice if the latch on the door opens up when locked and unlocked? You may have to use some WD-40 or somethin'
That should help
Old May 15, 2015 | 07:30 AM
Old03SSDriver's Avatar
Default reply
The power door lock fuse is in the dash facing the door on the drivers side. 20amp.
tps221
Mar 24, 2014 01:32 PM
supercharged SS
Mar 28, 2011 02:32 PM
supercharged SS
May 19, 2009 07:46 PM
whitelite
May 29, 2008 01:10 PM
alphadragon
Nov 19, 2007 06:08 PM
