98 no start ignition question
Old Aug 27, 2011 | 05:43 PM
LawlessOne's Avatar
Default 98 no start ignition question
I've been looking and have seen info regarding procedure to reset passlock etc...
What I'm looking for is a good troubleshoot guide to do this for a 98, this model has the ignition in the steering column. everything I've seen so far concerns dash mounted ignition systems.
I'm going at this blind and someone else has already tinkered with it and supposedly replaced a "sensor". Whether this is supposed to be the passlock sensor or not, I have no idea.
So can someone give me a good run down of systematically tracking this problem? Starting say if it could possibly be a fuse, then ignition/starter module, then passlock sensor, then ignition sensor.
I don't have a problem doing the job, just need a little guidance, especially if I have to change the ignition cylinder in the column. I took a quick look over of the car and it didn't appear that I could get to the ignition without pulling the steering wheel. So I'd like to get an orderly approach, up to and including the pulling of the wheel to replace the switch (if necessary).
Thanks in advance!!!
Old Aug 27, 2011 | 09:05 PM
zipper's Avatar
All 5th gen Montes had ignitions in the steering column, but that doesn't matter. To be honest, I'm thinking that you need to replace the key. But check the fuses first.
pfugly
Oct 13, 2019 03:52 AM
jrjfam
Sep 18, 2013 01:59 PM
JayBay
Jul 8, 2013 07:31 PM
dennis7711
Nov 27, 2010 07:57 PM
ChevRev34
Feb 24, 2008 01:10 PM
