98 Monte still fiddlin with the can't shift out of park when cold problem
Old Oct 1, 2009 | 03:16 PM
Gbrown's Avatar
Default 98 Monte still fiddlin with the can't shift out of park when cold problem
Hello all,
I'm still futzin with the can't get out of park problem.
Do any of you know how to get the shifter **** (console shift) off of the shaft. I'd like to examine the switch.
Thanks!!
Gbrown
Old Oct 1, 2009 | 06:58 PM
MAMONTE's Avatar
I am not 100% sure, but on my 06, there is a screw in the ****. If you put it all the way into first, you can see it. I'm assuming I would un screw that, and it would come off...I really don't know for sure though. I also don't know if the 98 has a screw on it somewhere...Sorry I couldn't help more. But try putting it in first, and looking on the front side of the shifter for a screw or two. (the side that faces the radio)
Old Oct 1, 2009 | 09:01 PM
tommyz34's Avatar
on my 95 mc z34 its a clip on back side of shifter pry it out and shifter lefts off of it
Old Oct 2, 2009 | 09:48 AM
aussiek2000's Avatar
There is like a c-clip thing that slips into a slot on the backside of the ****. I am pretty sure it will come out with a magnet.
Old Oct 4, 2009 | 10:08 AM
RJ87SS's Avatar
Default won't come out of park
My '98 had this same problem. I left it in Neutral and set the brake until I fixed it. It ended up being the shift interlock mechanism & had to have it replaced. I had it fixed at the dealer. Lubing it only helped temperarly. Like I said I eventually had to replace it. You might have to get to that from underneath.
Old Oct 4, 2009 | 04:59 PM
Gbrown's Avatar
Default Leaving it in neutral
Hello, I can't leave my car in neutral because you can't turn off the key to take it out.
How did you do it?
G
peteygnyc
Jun 29, 2019 02:04 PM
95mcarlodan
Dec 31, 2014 02:00 PM
northerner
Apr 9, 2013 10:34 PM
Sciggy
Feb 19, 2007 02:31 AM
desighitter
Feb 6, 2007 03:19 PM
