95 obd ?
Old Jul 28, 2010 | 06:59 PM
thesnaggle's Avatar
Default 95 obd ?
does anyone know if the 95 is the version 1 or 2 my plug in box under the dash has obd ver 1 connector but the pins are not the same as the one i had in my caviler
Old Jul 28, 2010 | 07:56 PM
mrl390's Avatar
Technically the 95s are OBD 1.5. Doesnt have the tunability of OBDII but it still has a MAF sensor.
Old Jul 28, 2010 | 08:12 PM
thesnaggle's Avatar
is it possible to get the trouble codes out of it without buying a scanner
Old Jul 29, 2010 | 01:13 AM
nitehawkjcb's Avatar
I know with my OBD1 car, I get a piece of wire and put each end in a connector under the dash. The CEL blinks long, then short to give you the code. For instance, two long blinks and four short blinks is a code 24.
Old Jul 29, 2010 | 08:00 AM
Isn't the 95 the only model withOUT the MAF sensor??
Old Jul 29, 2010 | 06:29 PM
mrl390's Avatar
I know for sure the Z34s have a MAF. I dont know about the LS models tho.
RocknSS04
FWD Tech Guides '95-'07
18
Nov 22, 2012 01:05 AM
Robkeith2007
Jun 16, 2010 07:56 PM
andwes03
Apr 12, 2009 06:13 PM
z34phoenix
Dec 6, 2006 12:33 AM
rockillaZ
Oct 26, 2006 11:37 PM
