86 monte ss a/c help
Old May 2, 2009 | 10:52 PM
spankrz's Avatar
Default 86 monte ss a/c help
hey guys, i'm new here so take it easy on me
i'm havin some trouble with the dash vents on my 86 ss. the defrosters and the floor vent blow hot or cold, as they should, but the dash vents don't blow at all. i read somewhere that the problem is the "flapper" in the dash, and it is stuck(the same one that makes the BANG) but i don't know how to get it unstuck. any help?
Old May 2, 2009 | 11:42 PM
Draciel's Avatar
I definitely have the same problem. So any help would be appreciated.
Old May 2, 2009 | 11:57 PM
spankrz's Avatar
i've been reading around at it seems like this is a common problem. apparently most of them made a "bang" when they opened, and ours did almost since it was new.(my mom bought it new). it sat for around 4 years and didn't get used, and i guess during this time it sealed up pretty good. i just can't figure out how to get it loose, as i drive it a lot now.
Old May 3, 2009 | 07:51 AM
The Popcorn King's Avatar
If they are vacuum controlled, whick i think they are, they might have either fell off, or developed a hole. I think you can remove the glovebox and see them. Also check your controls for loose hoses.
Old May 22, 2009 | 04:01 AM
vincenti's Avatar
sounds like the cable that selects either floor, defrost or vent is stuck on something. pull the temperature select plate and see if something like a piece of foam is getting in the way of the cable
jaydflash
Aug 29, 2014 03:38 AM
LegaBone
Aug 20, 2012 03:30 PM
rmase182ls
Feb 28, 2011 03:57 PM
cj702
Aug 20, 2006 03:20 AM
