85 Monte Carlo won't start
I have a 85 Monte Carlo 4.3 it won't start. I replaced the starter still won't start. I replaced the timing chain and all of the seals that goes with it and still won't start. I checked the distributor cap its good. I got fuel and spark but it won't start. It sounds like it wants to start it cranks but just won't turnover. I had it started for like 2 mins after I put the new timing belt on and it died but before it died it backfired really loud and there was smoke coming from the carburetor. Does anybody know what is going on? I need help I don't want to sell it. I just bought it a week ago. Please help me I am stomped. It has only 80,000 miles on it. Thank you
RE: 85 Monte Carlo won't start
That could be that you don't have enough compression in the cylinders, but if it backfired that means a valve stayed open when it wasn't supposedtoo. Which could mean the timing chain is off timing. did you replace your head gaskets?, a bad head gasket would cause lose of compression.
Hi `Steve from the Buckeye State of Ohio, and welcome
to the MCF.
It is difficult to give you a solution to your problem by just your
written words, but it could be that your timing is `off.
Did you use a timing light, and dial it in after your install ?
If you have spark & fuel to your cylinders, and it did
fire for a few minutes. You may have to check your
install of your new timing chain to confirm that it was done correctly.
Be patience, and hopefull one of our expert member tech will
post their thoughts/solution to your problem.
Steve, wish you good luck on your problem.
`Space
Steve, Check out the below links that may help you with your problem
Good Luck
AutoZone.com | Repair Info | GM Astro/Safari 1985-1996 Repai... Install the oil pan. Make sure the woodruff key is installed in the end of the crankshaft, then install the timing chain (4.3L only) and gears. ...
www.autozone.com/servlet/UiBroker?ForwardPage=/a... - 114k - Similar pages
http://www.autozone.com/servlet/UiBr...3d8011830b.jsp
AutoZone.com | Repair Info | GM Astro/Safari 1985-...
4.3L Engine. See Figures 3 and 4. Click image to see an enlarged view ... Install the timing chain and camshaft sprocket, making sure to align the timing ...
www.autozone.com/servlet/UiBroker?Forward... - 109k - Similar pages
[ More results from www.autozone.com ][/align]
Where is the coolant temperture sensor located it at? A friend of mine had the same car I have and his sensor went out and did the same thing mine is doing but he didn't tell me where it was located it at. Pics will be helpful
thank you
thank you
uortiz714
05-04-2012 09:12 AM
monte2001carlo
01-12-2011 06:17 AM
Mattw.2009
08-01-2010 02:27 PM
ChevRev34
02-24-2008 02:10 PM
