4t65 maintainence
Old Mar 17, 2008 | 04:05 PM
rysZ34's Avatar
Default 4t65 maintainence
I have 143,000 on my MC and at 139,000 had a trans. flush. Is there any other maintainence that should be done? Tightening of belts, solenoid adjustment? I'm NOT knowledgeable in transmissions at all and before I get charged by the local trans shop to look at the trans, I wanted to ask here. Thanks a lot!
Old Mar 17, 2008 | 04:19 PM
RickCoMatic's Avatar
Default RE: 4t65 maintainence
You might be close to where you'd want to replace or clean and repack all the wheel bearings.
Old Mar 18, 2008 | 06:45 PM
RocknSS04's Avatar
The tranny is all electronic and totally computer controlled. As long as you changed the filter and not power flushed it, you should be all set. The only adjustments are made thru the computer, and they are GOOD!
Old Mar 18, 2008 | 11:20 PM
rysZ34's Avatar
I'm hearing this noise, it's at low speed until about 30 mph. It's hard to describe the noise so bear with me. It's nota "clunking" persay, more of if you took a plastic glass and dropped it on the ground and that's what it sounds like.
bob442
Dec 8, 2010 09:38 PM
l0gitech87
Aug 27, 2010 09:47 PM
88ss408
Aug 21, 2008 07:58 AM
BeachBumMike
Aug 2, 2007 06:38 PM
