4 monte ac issue
Old May 12, 2014 | 03:25 PM
Rick Landry's Avatar
Default 4 monte ac issue
hello all. im new here and was hoping someone could help me. my ac is acting strange, i turn on the switch on dash and mt blower works and all else too except that the clutch on the comp wont engage. is that a relay, low 134 or what. any ideas... thanks
Old May 12, 2014 | 03:27 PM
Welcome to the forum. I am sure somebody can help you with that since I do not know.
Old May 12, 2014 | 03:39 PM
FYI - Moved this out of the New Member Section and into the Monte Carlo Repair Help section.
As for the clutch on the compressor not engaging, a good portion of the time, this is due to low freon levels (which would be the result of a freon leak somewhere).
IMO - Best thing to do is find a trusted shop that works with A/C systems take a look.
Old May 12, 2014 | 04:15 PM
Blazed SS's Avatar
IT HERTZ
I agree Low Freon or bad compressor best to get it checked by a good shop
Old May 12, 2014 | 04:17 PM
hillbillywizard's Avatar
More than likely, you have a leak that has allowed the R134a to escape. The low side switch could be bad, as those are known for failing. Take it to a trusted mechanic.
thtGuy
May 7, 2013 08:09 AM
radiantdragoon87
Oct 17, 2008 12:46 PM
boakesb
Jun 19, 2007 03:29 PM
02on20s
Oct 21, 2006 03:12 PM
bladehines
Mar 11, 2005 08:28 PM
