3800 top speed/ limiter removed
Old Jan 31, 2011 | 05:55 AM
chevy 224's Avatar
my 2003 monte tops out at 122 with the limiter
Old Feb 1, 2011 | 08:45 AM
zipper's Avatar
Holy old thread Batman!
A word to the wise, never EVER go these speeds in OD. The reason is because the 4th clutch hub and shaft are very weak from the factory, especially in cars before 2003ish. Going these speeds in OD is a very quick way of losing 4th gear (OD) so don't do it.
My 98 Monte's stock limiter was around 107ish mph. I now don't need to worry about it because of the tune for the PCM. If you don't want the speed limiter, just get a tune from someone (like ZZP) and you will be set. The reason my limiter is gone is because I will be going faster then 107mph the next time I go to the track. Hitting a limiter while at a drag strip sucks, lol.
Old Feb 7, 2011 | 12:56 PM
gmcman101's Avatar
Default Top speed
Yea, I have a 2003 and it topped out at 122 also, with the limiter.
Old Feb 7, 2011 | 01:14 PM
Crusader SS's Avatar
Before I put in my Tuned PCM, mine would hit 160km/h (103 mph) in 3rd gear and 189km/h (122 mph) in OD w/limiter... I am very glad I read this thread as I have had her past 210km/h (136 mph) in OD without limiter... Had no idea that was bad... Thanks,
Old Feb 7, 2011 | 02:10 PM
augi's Avatar
Is there a way to make 4th gear have the ability to go handle those speeds?
Old Feb 7, 2011 | 03:48 PM
zipper's Avatar
Yesish. If you don't have 4th gear or want to upgrade you can get a hardened 4th shaft here: http://www.tripleedgeperformance.com/Hard_Parts.html
Old Sep 13, 2011 | 10:02 PM
my03MonteLS's Avatar
how can i remove the top speed limiter and how do i know if mine has the hardened 4th gear?
vincenti
Dec 4, 2013 12:56 PM
MyIntimidator
Dec 21, 2010 05:54 AM
montejass
37
Mar 26, 2008 10:54 AM
fever42
Nov 26, 2005 04:42 PM
big green dog
Jul 10, 2005 07:47 PM
