3.8 Screeching engine after intake manifold /coolent repair
#31
Still no answers here , Anywhere I take the car they want me to leave it with them at a charge or take it back to the people who did the repairs (that's not a option anymore) All this money spent and the car is sitting in my garage now.
Can the fan be easily unplugged to see if that's the culprit ? Fans don't cost much but still going to be a lot for labor . The one part I did not replace could be the trouble , Why would the repair shop not hear this ?
a/c compressor making noise after the engine is off is still a possibility too .
#32
The fans are very easy to unplug takes about 2 seconds. As for changing the fan or both fans would take less than 2 hours probably get from a salvage yard for less than $50 . Were you at the repair shop in front of the mechanic when this noise was happening ?
#36
You had it right all along ,It's the fans . noise is gone when the fans don't run . I betcha those idiots at the repair shop did not even check anything and came up with the analysis that's the ac compressor and a alternator pulley . Thing is they should if replaced the fans when they put in the new radiator .
#37
Unfortunately, you have shops that do good work and others who don't. If you must rely on a mechanic (that you are limited in what you can do for yourself), then treat this like a doctor. You want the guy you trust and is a straight shooter. He might not be the cheapest, he might not be the most expensive, but if he is honest and his diagnostics are right almost all the time, he saves you money by being right and saves you aggravation by meeting your expectations.
The fans are easy to replace, no big deal. As for the $50, you paid them for time to do diagnostics. Sadly, does not always mean they are right (go back to my statement comparing the mechanic to a doctor). Just be glad you did NOT have them change that ac compressor!!
#38
I'm with the Maniac, find a mechanic you can trust. One important thing to remember is let them diagnose the problem, don't hand them the part or say change this because they will and then ask if you want to fix the problem. When I was fixing cars anyone who brought there own parts into our shop would be charged more per hour because of that reason and we would only warranty the labor. So unless the engine fell out or the part was installed wrong it was on you for supplying the parts. Do you bring your own hamburger to McDonald's and ask them to use yours to save money ?
#39
#40
