3.8 Screeching engine after intake manifold /coolent repair
![Smile](https://montecarloforum.com/forum/images/icons/icon7.gif)
How is the fluid level in the power steering pump? they will talk to you if they are low.
I checked google and found this for a youtube videos check the links![Thumbsup](https://montecarloforum.com/forum/images/smilies/thumbsup.gif)
https://www.google.com/search?source....0.pibiB51E1WY
pulley noises
https://www.google.com/search?source....0.2Y54qq735GA
pulley noises
Sorry it has been a few days. As you said, plugs are not a big concern, I was simply curious about the choice.
As for the noise, I was trying to follow the information but I believe I got lost in it.
So these are shots in the dark. If you have the tools to remove the belt, you can do that and then spin each pulley by hand and see if there is any weird noise or rough spots in the rotation.
You could also run the car for about a minute just idling and little revving in the driveway with no belt (remember, no belt, no water pump to keep the car cool). If you hear the noise without the belt on, you know it's NOT the Alt, power steering, AC compressor or water pump.
I have known on 90's GMs that the AC compressor can develop a metal scraping noise I believe it's a result of problems with the clutches in them). And I already mentioned the PCV valve/o-ring item.
Well it's been in the shop since Tuesday , They don't know what it is yet. It's not the fan,pulley bearing or tensioner,ac condenser,fans,belt, alt , none of it .
The noise does not start till the car is been driving for about a 1/2 hour on a 80 degree day . Then it does it with the ac on or off and it is not constant . a loud metal screeching. I would say a pulley bearing but they said it would be a constant noise on all of the above mentioned . So when putting the manifold on did they screw up something and don't want to tell me or they just do not know ? The car runs great , No more leaking anywhere but that noise is unbearable and eventually something will fail . I'm not sure what to do while waiting for them , I'm not sure what they will tell me tomorrow . The noise seems to be coming from the front of the car .
You said the noise happens with and without the AC running. Does the noise happen when you have the car in park and are just idling? Does it change while in park and lightly revving the car?
When the cooling fans activate, the the noise start or stop?
Has anyone removed the belt and spun the pulleys by hand, feeling and listening for rough spots in the rotation of the pulleys? Has anyone checked the engine oil? Does it have metal in it, is it low, is the color unusual?
Can you narrow down a more specific region of the car (the front of the car can cover a lot of territory).
And again, knowing they change the upper intake, I would check where the PCV sits, verify the O-rings are there for it (I'd have to pull the diagram for the install of those rings), as I've heard a couple other people found that to be a root cause to a noise they thought to be an alternator.
At the moment, that is the full list I can suggest without seeing and hearing the car myself in person.
The noise comes at anytime in park or idle , comes and goes and it does not change when there fans are on or off . I'm not sure what they have tried to do yet and by the way there talking and not knowing what it is , sounds like something is up with the manifold install . They probably did not know how to do the o-rings . I should have asked more questions before I picked them to do the work and the labor is not guaranteed because they used my parts , They told me it took a long time to figure out the elbows and the egr , Is that where the pcv is or opposite side ?
There are no apparent leaks at the moment . I'll have to see what they say and have them check all this stuff that you mentioned , thanks for all the info , it's very helpful .
If this shop has been in business for any length of time, they should be pretty familiar with the elbows and EGR, nothing odd about that.
Anycase, attached are some pictures I found thanks to Google of the 3800 PCV. And here is a write up about it from an Impala site:
2001 Impala How To
Hope this helps. It's very easy to get to.
2001 Impala How To
