3.5 Monte stops accelerating around 2k rpm
Old Feb 24, 2011 | 09:41 AM
06-montelt2's Avatar
Unhappy 3.5 Monte stops accelerating around 2k rpm
HELP!!!! My monte is a 2006 3.5 lt.
So on my way to work this morning my car had stopped accelerating at around 2k RPM's and about 55MPH. Basically i would hit the gas and the RPM's didnt increase nor did the MPH, the car actually started to slow down... So i let go of the pedal then slowly worked the RPM's back up to speed and it works that way.
Theres no check engine light, i did some work on my intake last night took it apart painted the piping with some high heat ceramic black paint. While i was wating on the paint to dry i did take a can of compressed air just to clean the MAF out a bit. Hooked it all back together then roughly 15 miles later these problems occured.
Maybe i damaged the MAF with the compressed air?
Ive heard it could be a number of things ranging from the most expensive of a tranny, down to a bad alternator, battery, plugs/wires, belts, timing, and anywhere along fuel delivery....
I havnt troubleshooted anything yet and its going to the mechanic tonight so hopefully someone can let me know if its a simple fix before i do so.
Oh yeah and it does have close to 101500 MI on it...
Thanks fellas!
Old Feb 24, 2011 | 11:56 AM
Default Update
Went out for a lunch break to get wendys about a mile or two away... Before i left i unplugged the MAF, started driving with no problems at all. Got wendys and before i left wendys i plugged the MAF back in, no problems at all. Maybe it was a loose connection? maybe the MAF is starting to go? or maybe the MAF is still not even the problem.
I will keep you guys updated.
Old Feb 24, 2011 | 12:43 PM
could also be the cat, it gets clogged and then you lose all power, that should probably still be under your warranty?
Old Feb 24, 2011 | 01:32 PM
I think i might be out of the warranty... I have 101k miles on it, unless the cat has its own warranty?
Old Feb 24, 2011 | 02:22 PM
Sometimes Cats do if they are known to be faulty. But being an 06, IDK if they are faulty like the 00-04 cats.
You can damage a MAF by using anything on it besides MAF cleaner, so just keep an eye on the MAF and see if it happens again.
Old Feb 24, 2011 | 02:40 PM
MillerMonteSS's Avatar
2010 Monte Of The Year
Good luck. Definitely keep us posted.
1988BlackMonteCarloSS
Nov 21, 2014 12:05 AM
ChicagoMonteSS
Jun 7, 2012 05:42 PM
anarchy1974
Dec 4, 2008 10:55 AM
vita
Mar 26, 2008 06:13 PM
rj
Jan 27, 2008 02:04 PM
