2007 5.3 Monte Carlo Thermostat Question
Old Sep 8, 2013 | 04:05 PM
Daymack's Avatar
Default 2007 5.3 Monte Carlo Thermostat Question
I looked at the housing holding the thermostat on my 2007 Monte Carlo 5.3 and it looks like it's going to be difficult to get to the bolts on the housing.
Has anyone changed a thermostat on the 5.3 and any suggestions for the best way to get to the bolts?
Old Sep 8, 2013 | 06:00 PM
IslandMonte's Avatar
I found a pretty helpful step by step on youtube for the '05. The bottom bolt was the most difficult step in the process. I noticed that the mechanic in the vid was under the impression that he needed to remove that bottom bolt completely, but when he removed the housing there was a slot instead of a bolt hole. I think you may be better off loosening the bottom bolt a couple of turns and see if the housing slips off with the top bolt out. (Top is a hole, bottom is a slot). Good luck.
Old Aug 28, 2015 | 03:56 AM
royalbluecity's Avatar
Awaiting Email Confirmation
can you show me where it is located the thermostat on a 2007 monte carlo ss
dcm0123
Sep 7, 2012 08:46 PM
Scooby doo
Mar 23, 2010 09:56 PM
Twisted_Metal
Sep 27, 2008 02:12 PM
joegarcia39
Jun 2, 2008 10:02 PM
TonySS2007
Jan 11, 2008 04:51 PM
