2006 Monte Carlo SS transmission noise
Old Feb 17, 2011 | 06:44 PM
nat120's Avatar
Default 2006 Monte Carlo SS transmission noise
Hi Guys first post. I have a 2006 Monte Carlo SS which I really like. I bought it about a month and a half ago. The transmission makes a grinding noise when shifting sometimes. If I am going about 25 to 40 mph and give it gas when it shifts it makes a grinding noise. Kind of like if you took your hand and rubbed it on a leather chair. I was disappointment once I bought the car that there is so many people having trouble with transmissions and and the engine problems. It sounds like many people are recommending having the DOD turned off to for go oil issues and engine damage.
How many people have had the same transmission problem?
Old Feb 17, 2011 | 07:16 PM
06LS4's Avatar
Great purchase! Unfortunately, the transmissions are the weak link... However, if you keep the trans fluid and screen serviced, every 30k, the trans will hold up; at least this is what i was told by a friend who works at chevrolet service department. (AFTER my transmission went out and was being replaced)! When you think about it, it's a small price to pay; it works out to be about once every other year? As for the oil consumption, GM has figured out what the problem is. The fix will be avaliable soon. Keep tabs on your oil consumption and let the dealer know; they'll take care of it and you wont have the problem anymore. They know exatly why our motors are using the oil. Plus, even if you did turn of the DOD, why shouldn't you be able to benefit from the DOD design when you decide to travel; you sure paid for it? (I drove from Detroit to California for just under $300.00, running premium all the way; this was when Gas was nearly $5/gal)! The DOD does wonders on LONG trips... otherwise I don't think it really saves that much? Overall, the car is very dependable; that 5.3 is strong and durable!
Old Feb 17, 2011 | 07:32 PM
nat120's Avatar
Thanks for the reply. I have been looking on the internet for companies that rebuild the transmissions in these cars so I will last for a long time. I came across this company and have an email in to them. http://www.transmissioncenter.net/alto_2.htm
The fluid in my transmission looks so clean that it may have been recently changed but I am not sure.
The issue with the DOD and oil comsumpsion, I wonder what the dealership is going to charge for that. My car is not under warranty and has 52,000.
Does anyone think that having the transmission reprogramed/tuned could fix this issue? It was something mentioned to my by buddy of mine.
Old Feb 17, 2011 | 08:37 PM
Chev E. Chelios's Avatar
N00B SAIB0T
I'm a newbie with an 06 SS, any tips for using the DOD, all I do is let off the gas to activate 4 cylinder mode,is there anything else I should try other than this method? I tried using cruise control but it stayed on 8 cylinders. Any tips would help.
Old Apr 17, 2011 | 12:43 PM
iceman56607's Avatar
Originally Posted by nat120
Thanks for the reply. I have been looking on the internet for companies that rebuild the transmissions in these cars so I will last for a long time. I came across this company and have an email in to them. PATC 4T65E Performance Transmission, 4T65E and 4T45E Parts
im also curious about the reprogramming or tuning?
maybe a new chip?
Old Apr 23, 2011 | 10:13 PM
06LS4's Avatar
Sounds like the torque managemant kicking in... same noise as the traction control? I bet your wheels were turned? if you accelerate hard with wheels turned, the torque management kicks in to prevent you from breaking the CV shafts. did it take away fueling and sputter?
SanJoseSS
Nov 1, 2015 10:31 PM
SanJoseSS
Feb 1, 2013 01:29 PM
Slugger088
Nov 21, 2011 09:01 AM
slinkeey
Jun 24, 2010 12:25 PM
24_48Fan
Oct 20, 2009 02:34 PM
