2006 Monte Carlo Service Battery Charging System
Old Jul 13, 2013 | 10:51 PM
aspiringthomas's Avatar
Default 2006 Monte Carlo Service Battery Charging System
I was working on installing some headrest monitors and ran my battery partially down. It was able to start but at the moment the service battery charging system is coming up on the dash. I checking the battery while it was running and it was putting out 13.5 volts. Thanks for any info.
Old Jul 13, 2013 | 11:29 PM
I WOULD RECOMMEND...
Once the battery is back at full charge...
Try to Disconnect the battery for 5 mins to reset the computer...
Then reconnect it and see if the light/message disappears...
Or, go to your local auto parts and see if theres an issue...if not//Then just have them clear the code..
2006SSMC
Oct 6, 2021 02:21 PM
Randdady
30
May 29, 2011 01:02 PM
LTLDEVL
Dec 2, 2010 02:08 AM
Tballard182
Sep 20, 2010 06:48 PM
White06MCSS
Nov 11, 2007 03:16 PM
