2005 Monte LS High Beam issue
Old Dec 17, 2011 | 11:29 PM
tj4ndirish's Avatar
Default 2005 Monte LS High Beam issue
A couple of weeks ago the high beam on the driver's side high beam stopped working. Yestereday, while changing the oil, I decided to look at it. I pulled the bulb and looked at it and it looked fine. So, I pulled the the passenger side one and put it in the driver's side, it didn't work. So I put it in the passenger side and it worked. So, I verified the bulbs were both working.
I looked at the owner's manual to find the fuses. I pulled the one, that I thought was for the driver's side and the fuse was fine. So, I pulled the one for the passenger side and switched it out, and still nothing. So, not the fuse. Now, when I went to put the fuses back, the passenger's side light started flickering and went dim and the radio went in and out and finally off. I tried to start the car and it was dead.
I jumped it and ran it for a bit. It sat over night and it ran fine today.
So, I've got 3 questions.
1. What would cause just the driver's side high beam to not work?
2. Is the another fuse I need to look for?
3. And why would the car go dead when trying the fuses?
Thanks for your input......
Backburner007
May 13, 2015 07:31 AM
MonteCarlo579
Jul 6, 2014 11:46 AM
Huckster
Mar 2, 2014 05:59 PM
Bigg J
Dec 9, 2007 09:06 PM
Swonk
Jan 31, 2006 12:29 PM
