2002 Monte Carlo SS high beam out
Old Mar 1, 2014 | 04:10 PM
Huckster's Avatar
Unhappy 2002 Monte Carlo SS high beam out
I have a 2002 Monte Carlo SS, that for some time the high beam switch has been acting up on me. Started out not staying on "hi" when pulled back on lever. Then made a "cracking" sound when tried to put on High beam lights. Now won't stay on High beam at all. Is this a fix a "kind of handy" guy can fix? Or will this be a "stealership" over charged fix i'm looking at?
Anybody experience the same issue???
Old Mar 1, 2014 | 04:14 PM
Crusader SS's Avatar
My hi-beams have never stayed on, all I can do is flash them... I did install the HID's on the low beams and now have no use for the hi's... It's an option and will be much cheaper than the dealership, I paid $125 for mine in Canada... Should be cheaper for you...
Old Mar 1, 2014 | 04:25 PM
Huckster's Avatar
Not sure what you mean by HID's, I guess I don't need them as long as all the other functions on lever works. Directionals and cancel off properly. Just kind of bugs me.
So far since I had car most issues come from the plastic "cheapo" dash controls. Wish better design / construction was used when car was manufactured....
Old Mar 1, 2014 | 08:50 PM
Here is an explanation...
High-intensity discharge lamps (HID lamps) are a type of electrical gas-discharge lamp which produces light by means of an electric arc between tungsten electrodes housed inside a translucent or transparent fused quartz or fused alumina arc tube. This tube is filled with both gas and metal salts. The gas facilitates the arc's initial strike. Once the arc is started, it heats and evaporates the metal salts forming plasma, which greatly increases the intensity of light produced by the arc and reduces its power consumption. High-intensity discharge lamps are a type of arc lamp.
High-intensity discharge lamps make more visible light per unit of electric power consumed than fluorescent and incandescent lamps since a greater proportion of their radiation is visible light in contrast to infrared.
Old Mar 1, 2014 | 09:40 PM
Huckster's Avatar
Red face
I see, sounds high tech.
I just looked up the install of the high beam, wiper, signal lever. "You tube" video shows a 2004 Impala install. Not all that hard to do. Part is $84 up to $280.00
Looks like a Spring project for me.
Old Mar 2, 2014 | 10:34 AM
Huckster...
Heres a thought...
I was wondering.... Maybe its a push for high beams? Instead of a pull?
on my 03 and 04's its a push for high beams and a pull for flash...
I could be wrong..but something to consider...
Changing out that module is no biggie..just time consuming somewhat
Besure to et us know how it went...
Some pics/video would also probably help our members for future use..
Thanks!
Old Mar 2, 2014 | 12:23 PM
ohara's Avatar
Originally Posted by STUMPMI
Huckster...
Heres a thought...
It is a pull for our cars. And you need a new lever, it is fairly cheap and not too expensive, well the last one I had to do was on my cavalier, but the wifes monte needs a new one too, just haven't got around to doing it yet, she doesn't drive after dark very often so no real rush lol
Old Mar 2, 2014 | 12:34 PM
Yup, it's definately a pull... Interesting, it seems the module fails on quite a few of our cars..... Maybe a design flaw, never had one go on any of my vehicles prior, although I did break one years ago by accident... Good luck with the repair...
Old Mar 2, 2014 | 05:59 PM
Huckster's Avatar
Thanks, when we start getting warmer weather I'll dig into it. After watching the YOU TUBE video on replacing one on a 2004 Impala, (same part) not too difficult to fix. Not a big deal that I need hi beams but just bugs me how cheap these parts are made. AC Delco's are priced in the $280 + price range. Aftermarket on EBay sell for $40 bucks. Just got to make sure I get the one WITHOUT cruse control. Not sure I would go with AC Delco if so many people have same issues as I.
srbecker58
Nov 3, 2014 11:11 AM
MonteCarlo579
Jul 6, 2014 11:46 AM
dupree155
Mar 2, 2010 05:25 PM
srbecker58
Jun 17, 2009 11:35 PM
Swonk
Jan 31, 2006 12:29 PM
