2004 SS volume control
Old Jun 16, 2019 | 07:26 AM
BarryU's Avatar
Default 2004 SS volume control
Does anyone have experience with the manual volume control stop working and auto volume is less than sufficient? I have checked power supplies to the amp both 12 volt sources are there as well as good grounds. I have been not been able to find a schematic or any info that would help me to identify the sensor or how to measure resistance or miliamp specifications. Any and all suggestions would be appreciated. Happy Fathers day
Old Jun 16, 2019 | 09:30 AM
Not sure I fully understand the question. Are you saying when you turn the **** up, all is fine? But the feature to increase/decrease volume based on your driving is not working?
If so, I assume you are still using the factory radio? For me, I don't like that feature, so I turn it off (somewhere in the radio options is an on/off control). You may want to see if it's simply turned off.
Old Jun 17, 2019 | 07:42 AM
BarryU's Avatar
Thanks for your suggestion. The option if we are talking about the same option does not work. If there is an embedded option I have not found. Radio just seemed to change one day. My car was garaged for long periods of time i believe the battery died once as well. I'll keep digging thanks for your help.
Kollak81
Mar 31, 2019 03:56 PM
Storm1701
Mar 27, 2015 11:34 PM
Tadcaster
Feb 2, 2012 09:21 AM
carlohog
Nov 4, 2011 10:54 AM
TonySS2007
Jan 11, 2008 04:51 PM
