6th Gen ('00-'05): 2004 SS traction control comes on randomly
Old Feb 26, 2014 | 02:08 AM
alexd757447's Avatar
Default 2004 SS traction control comes on randomly
So, pretty much every time I pull out of my driveway or a parking spot as I turn and start to accelerate my traction control activates, and occasionally the service traction system warning comes on as well as the traction off and ABS light. I have also noticed a slight rubbing type sound from the front wheels when I turn left, not sure if the two problems are connected. I'm not really sure what the problem could be, any ideas would be appreciated.
Old Feb 26, 2014 | 05:41 AM
03SSLE's Avatar
The most common cause for the traction off/abs light combo is bad wiring to one of the abs sensors or a worn wheel hub. The abs sensor is an integral part of the hub, and as the bearing wears it skews the signal from the sensor which triggers the lights. If you have the stored/pending codes scanned it will let you know which hub is bad.
David McDougal
Aug 8, 2012 11:31 AM
Jul 8, 2012 08:27 AM
erickson483
Sep 19, 2010 01:57 AM
seawolf18
Jan 14, 2010 07:28 PM
Joe Bloggs
Nov 9, 2009 03:36 PM
