2004 SS Brake Rotors
Old May 31, 2005 | 11:49 AM
ralphtrent's Avatar
Default 2004 SS Brake Rotors
Hi
I have an 04 SS with 5183 miles. I have noticed that the rear brakes, grooves are being etched into the rotors. I called the dealership and they said that the problem may be rust which has happened on other chevy's but not so much with MC's. They said that can look at it, but I am afraid that this may not be covered under warrenty. This is just the latest problem to happen with my car in such a short time.
Any thoughts, please let me know.
Thanks!
Old May 31, 2005 | 12:10 PM
mickey's Avatar
Default RE: 2004 SS Brake Rotors
mine rust up every time i wash the car amazing how fast it happens to
but rust will wear off the first time you hit the braks gogn down the street.
I have heard of other having problwmes withthe rotors warping and also groving up
I have been relativly luck with this issue Thanks God over there they are cheap here they have to order them
might have a bad set of pad on the car also
good luck
Old May 31, 2005 | 03:05 PM
big green dog's Avatar
Monte Of The Month - July 2005
my bro has a 2000 mc and his rotars warped it is covered by warrenty though so ur in luck
Old May 31, 2005 | 03:56 PM
montejass's Avatar
Our factory rotors are crappy. You are going to want to upgade to slotted/cross drilled anyway later down the road. But, since it's under warranty I would run it in.
I would suspect at only 5K it would be covered.
TVW
slurb
Mar 9, 2010 11:09 AM
HaRvArDaLe
Nov 21, 2007 09:03 PM
hermtm2
Oct 9, 2007 10:00 PM
phoenix_iii
Mar 22, 2006 11:00 AM
mickey
Oct 7, 2005 06:52 PM
