2004 Monte Carlo Turn Signal Switch Repair
Old Oct 24, 2011 | 05:54 AM
oldpitpony's Avatar
Thanks for the replies guys!
I wonder if anyone had any luck hooking up a bright / low bypass switch type thing?
I have changed that turn signal stalk on my '94 Grand Am about 4 times over the years I've had that car (since '03). That doesn't count the other mid-90's Grand Ams I've done it on (I can do the job in roughly 15 minutes, maybe 20, and I know just the tools to get for it from my garage). Every time I finally broke down and changed mine, I lost the ability to click my high beams on (I could hold the wand forward to keep the highs on). But since I hardly use high beams, I did not worry until I had a bigger problem (fogs turn on, but not head lights or turn signals fail). First one I bought was $70 from a local parts store, then a warranty swap, a $10 salvage one and lastly, I just installed one I pulled from my friend's '95 when we junked it this year (his was roughly 6 months old).
Due to age and mileage, I am trying to keep the Grand Am on the road safely as reasonably cheap as I can. Next step may be to rig an auxiliary headlight switch else where.
My Monte currently has the can't click the high beams issue. Currently, at the ridiculous price places want for that part RocknSS04 mentioned), I am holding off until I have a bigger issue (or I find a cherry donor in the salvage yards). But it is truly annoying.
Old Oct 29, 2011 | 09:56 AM
fastpitchcrazy's Avatar
Default HELP..Turn signal lever I'm told..NO HEADLIGHTS
I have a 2004 monte carlo...headlights stopped working along with brights lights but daytime running lights worked....got a headlight switch and put it in and now have brights all the time but still no headlights..now I'm told I need a turn signal lever cause the one now will not allow me to dim the lights(will not click) and this will fix my problem..any help would be appreciated..Thank you
Old Oct 30, 2011 | 10:05 AM
Vette no more's Avatar
Install a pair of 12K HID lights and you'll never even use the high beams...............
Old Dec 7, 2011 | 08:24 AM
dkeizer05's Avatar
I looked up this great thread back in June when my switch went out on the Monte. But rather than spend the money on the switch I have just been driving around without a turn signal for the last 6 months and it hasn't hurt me none.
Old Dec 9, 2011 | 09:51 AM
nyfunny07's Avatar
I am going through the same problem on my 2002 Monte SS Dale Earnhardt Edition. No low beams. Just get high beams and DRLs and rest. Per the tech at the dealership, my module detected 14 warning errors from Airbag to turn signal to locks, etc operating too high or too low. Not to mention my headlights not working. Told me I need the main multi switch thats on the steering column. Parts and labor is $900..CRAP!!!
Old Aug 8, 2013 | 12:11 PM
mikey56's Avatar
Default turn signal
i was having problems with brights not clicking on and replaced turn signal lever and still no brights clicking on any suggestions?
Old Nov 26, 2014 | 10:29 AM
Del Monte's Avatar
Default Multifunction Switch
1a Auto has a start to finish video, that does not indicate a requirement to remove the instrument panel, only the two lower panels underneath the steering wheel. They also sell the part for $73 and change. If I have a problem with the part I will post again.
Habbibie
Jan 10, 2011 09:59 PM
NovaSS369
Aug 11, 2010 02:24 PM
Ein
Jan 13, 2009 07:45 PM
RickCoMatic
Jan 14, 2008 12:45 AM
Nortybignort
Jul 25, 2006 10:35 PM
