2004 Monte Carlo radio info
I have a 2004 Monte Carlo and have a question about the radio - the current radio does not have the security or tire pressure features but does have an issue with the CD player. If I got a radio from the same year car that also has none of the above features will it be just a swap? The car does have a security system but it is an aftermarket since the previous owner must have either lost the key fob or had the alarm system installed instead. The cassette deck works fine - even use it with an adapter for the aftermarket Sirius receiver since it is better than the cheesey window foil that tries to pass for an antenna.
someone else on here probably knows more than me!
There is a "simpler" looking CD radio I've seen on some of the Montes sounds like yours is one of them. Sadly, I don't know, but I suspect there is a chance it could be a straight swap. If you have to replace it anyways, i'd do it. OR upgrade to GM MP3 Radio 10348717 (it was offered in '04-'05 Venture Vans and Cavaliers). I put this radio in my Monte so I could play MP3s burned to a CD (looks exactly like my factory one and works with all the wheel controls). This model DOES require programming with a GM TechII (a scan tool used at most, if not all, GM dealerships).
If the vehicle was not equipped with an alarm from the factory then you won't have settings for that option in the radio, but the low tire pressure indicator was a standard feature so I don't understand why it's not there. To be honest, I wouldn't go through all the hassle and cost of replacing the radio just to have the tire monitor option in the radio. If the warning light ever comes on just turn the key to the ON position then turn your parking lights on/off 3 times within 15 seconds to reset it.
6th Gen ('00-'05): Need bumper cover info and lower body kit info - restoration
davidk67
May 10, 2012 09:21 AM
Ramairetransam
Oct 1, 2009 12:34 PM
