6th Gen ('00-'05): 2003 SS oil leak
Old Oct 31, 2017 | 03:45 PM
Anonemu's Avatar
There is never any smoke from burning oil. Sometimes there is some white smoke from my exhaust when at high RPMs
Old Oct 31, 2017 | 04:18 PM
plumbob's Avatar
White smoke from the exhaust is a symptom of coolant leaking into the combustion chamber, usually from a intake manifold gasket or head gasket leak.
I lean toward the problem being the oil filter or it's housing like Chibi said, or the front crank seal.
Old Oct 31, 2017 | 04:23 PM
Anonemu's Avatar
Okay that sounds like good news to me, I’ll be able to do some work on the car soon
Old Oct 31, 2017 | 04:51 PM
Anonemu's Avatar
Thank you
Old Oct 31, 2017 | 04:53 PM
plumbob's Avatar
Hope it helps, keep us posted.
Old Nov 4, 2017 | 10:41 AM
Malcolm Fay's Avatar
Look at the oil pressure sending unit right by the oil filter.
Old Nov 6, 2017 | 01:08 AM
96z34man's Avatar
The dealer can look it up and tell you if the recall's been done.
Also, white smoke doesn't always mean coolant. When you have an LS4, it means your DoD just went back to 8 cylinders, with a vengeance.
