2003 monte ss without any tail lights
I am having troubles finding out the reason why I dont have tail lights. everything else works, reverse, brake lights, turn, horn. etc. etc. I have checked the fuses but all seem fine. any suggestions?
thank you
thank you
This may sound dumb but did you at least try to change the bulbs to see if they work? Since you say you have brake lights when the pedal is pushed on then i do believe you are getting power back there...it maybe just the filaments for the tail light part of the bulbs could be burnt up? Just a thought for you to think about.Do the turn signals work when the brake pedal is depressed? The reason i ask is that i think the brake light and the turn signal use the same filament...check it out and post back..i am curious as to what your problem may be with your tail lights.I have one more question for you....do you use your light switch when it gets dark or do you use the auomatic feature that turns your lights on at dusk? If you use your light switch on your dash and pull it to the second position..then this just turns on your dash lights along with your tail lights etc....try to pull it out manually if you dont and see if your tail lights come on......it maybe a bad light switch?
thanks for the reply, however that is not the case. I took it to the shop today, and they want to take apart my dashboard and check out something. I forget exactly what he said, but I remember that it isnt cheap! Im going back tomorrow.
thanks for the help
thanks for the help
If you have (or can borrow) a 12v test light or a multimeter you can check the circuit at the tail light plug yourself. That way you will know whether or not you are getting power to the bulbs. Attach the negative probe of the test light/meter to ground. Pull the head light switch out to either the running light or headlight position. Touch the positive probe of the test light/meter to each of the contacts in the bulb socket. One of them should make the test light illuminate or the meter should show a reading/beep. If it does then the circuit is fine and you just need to replace the bulbs. If it doesn't then the head light switch, relays and wiring will need to be checked out. As BigAl mentioned, it could be that 1 of the filaments for the tail light was previously bad, and the other side also went so now you have no tail lights. I'd hate to see you pay a shop big bucks if it turns out to be a simple fix.
I finally got it fixed
it was a wire that wasnt connected behind my Radio. $150 to fix that little mess.. Im glad that I took it to an audio store, rather than a garage. the garage wanted so much money to take it apart and TRY to find the problem, I had the hunch that it happened right around the time I had my radio installed by a friend. but whatever, I am happy now
thanks everyone for your help!
thanks everyone for your help!Thread
01LS Goin Bad
Oct 28, 2011 12:48 AM
monte carlo 3831
Jun 4, 2009 09:36 AM
RickAKATed10
Jan 23, 2009 10:38 AM
