2003 Monte Carlo won't start!!
Old Mar 24, 2016 | 03:27 PM
Neilholland28's Avatar
Default 2003 Monte Carlo won't start!!
I have a 2003 Monte Carlo ss. I have a mechman 240 amp alt and a red top battery under the hood. The Monte won't start after I took my big stereo system out. All the original wires are still in place. But for some reason my door locks and jus about anything in the car has no power I put a volt reader to the relays and fuses under the hood and I have a 12+ but everything inside the car has now power. I'm very confused on why this is happening so if anyone has any ideas let me know thanks for looking
Old Mar 24, 2016 | 03:45 PM
Hi Neil and Welcome to the MCF.
Do you have any check engine lights ?
Did you check your connection to your starter ?
Bad Starter relay ?
Need help fast!!!!! Car won't start - Monte Carlo Forum - Monte ...
montecarloforum.com › ... › General Forums › Monte Carlo Repair Help
Aug 24, 2011 - Need help fast!!!!! Car won't start ... Try to jump the car, if it starts that way go buy a new battery. .... 2003 Monte Carlo LS Autobot "Storm Bringer"Engine wont turn over and no clicking - Monte Carlo Forum
Aug 18, 2012
Car Cranks but won't start... - Monte Carlo Forum - Monte Carlo ...
May 18, 2012
HELP! My 01 Monte LS won't start. - Monte Carlo Forum
Aug 6, 2009
Security Idiot Light flashing on dash and Car Won't Start
Jun 4, 2008
More results from montecarloforum.com
Old Mar 24, 2016 | 06:34 PM
Sounds like a ground or some other connection got removed when you took the stereo out, check all the wiring
Old Mar 24, 2016 | 08:07 PM
Question
I agree sometimes when you get inside and take out the aftermarket stuff it will want to mess with you. Check that ground wire for sure something went from the ignition switch to that aftermarket radio and when it left so did that connection. Good luck.
