2002 Monte SS stuck ignition key
Have a 2002 Montee SS, last week Key would not turn ignition , tried other key same thing, had car towed home [having to disconnect shifter cable at tranny], took dash apart-stuck in key - car started- not knowing what I did,,lubed cylinder,drove for a few days now sticks intermitently, should the key and tumbler be relaced or ignition switch, or both, thanks Baksu
RE: 2002 Monte SS stuck ignition key
Hi Mark, and Welcome to the Monte Carlo Family Forum
Sorry to read that you are having problems with your Monte.
Check out the below links on the problem that you are having.
If none of the below link information helps, please be patience and wait for one of our expert members to respond/post a solution to your problem. Wish you good luck and also look forward to your future posts and contributions to our forum.
[:-]Click on the below links & Explore [:-]
Steering wheel stuck Problem Solving at FixYa
key stuck in ignition. tried moving steering wheel and truning key. ... im 6'1 and i love driving my honda accord ex, 2002 model. ... I have a 2006 monte carlo ,came home and turn car off, went to go to the store car turns on ,but. ...
www.fixya.com/tags/steering_wheel_stuck - 50k - Similar pages
http://www.fixya.com/tags/steering_wheel_stuck
Free Download PDF Ebooks Files | Chevrolet Monte Carlo 2000 ...
Without pushing the accelerator pedal, turn your ignition key to START. ... remove a starter on a chevrolet 2002 monte (2) - 2002 monte carlo owners manuel ... chevy monte carlo owners manual online (1) - ford escort ignition key stuck ...
www.ebookspdf.com/automotives/3794/chevrolet-mon... - 39k - Similar pages
http://www.ebookspdf.com/automotives...owners-manual/
2002 Monte Starting Issue - Topix
DONT!!! wait on it because I did and got stuck about a good hour away from my house. ... I have an 02 Monte Carlo that won't start. The key goes in the ignition, ... Ihave a 2002 ss monte carlo its cost me 30dollars to fill up every 3 ...
www.topix.com/forum/autos/chevrolet-monte-carlo/... - 82k - Similar pages
http://www.topix.com/forum/autos/che...FO1CUE1RASJOA5
My 2003 Monte carlo won't allow the key switch to turn with ...
Key Stuck in Ignition, Key Will Not Return to Off Position, Shifter Button Won't Release in Park Position ... 2002-2005 Chevrolet Monte Carlo. Condition ...
www.justanswer.com/questions/mefi-2003-monte-car... - 31k - Similar pages
http://www.justanswer.com/questions/...wont-allow-key
2002 Chevrolet Monte Carlo Technical Service Bulletin (TSB)
Provides Information about 2002 Chevrolet Monte Carlo Recall, ... Key stuck in ignition, key will not return to off position, shifter button won't release ...
www.aboutautomobile.com/TSB/2002/Chevrolet/Monte... - 97k - Similar pages
http://www.aboutautomobile.com/TSB/2...et/Monte+Carlo
2002 Chevrolet Monte Carlo TSBs [ CarComplaints.com ]
2002 Chevrolet Monte Carlo TSBs (Technical Service Bulletins) ... TSB #060235005 KEY STUCK IN IGNITION, KEY WILL NOT RETURN TO OFF POSITION, ...
www.carcomplaints.com/Chevrolet/Monte_Carlo/2002... - 48k - Similar pages
http://www.carcomplaints.com/Chevrol...002/tsbs.shtml
key stuck in ignition and won't turn back to lock position (...
I have a 2002 trailblazer LS . I recently had a transmission malfunction ... Key won't release from ignition lock position unless battery was disconnected and even when ... Malibu, Monte Carlo, Cobalt, Camaro, Chevy Trucks, Vans & SUV's ...
chevroletforum.com/forum/showthread.php?t=5929 - 56k - Similar pages
http://chevroletforum.com/forum/showthread.php?t=5929
WikiAnswers - Chevy Monte Carlo Questions including "How rep...
Why does key get stuck in the ignition when car doesn't lock into park? [Edit categories] ... How do you Remove headlight assembly 2002 monte carlo ss? ...
wiki.answers.com/Q/FAQ/1047-40 - 81k - Similar pages
http://wiki.answers.com/Q/FAQ/1047-40
Automotive Recalls and Technical Service Bulletins for 2002 ...
... and Technical Service Bulletins for 2002 Chevrolet Monte Carlo V6-3.4L VIN E . ... 06-02-35-005 FEB 06 Ignition - Key Stuck In Ignition Switch/Won't Turn ...
www.alldatadiy.com/TSB/10/021007gn.html - 59k - Similar pages
The same thing happened to my 02 LS. the cylinder needs replaced. then the car has to relearn the new passlock for the security system.you can get your key coded to the new cyl/passlock. there should be some detailed instructions in do it youself. if you can get the radio out the cyl/passlock is easy to get to. a new cyl. was $130 thru a gm employee I know. if you take it to a dealer should be about $250 for labor and part.
7th Gen ('06-'07): Key stuck in ignition; solenoid?
PhillyZepHeather
04-30-2015 10:09 AM
6th Gen ('00-'05): Key stuck in ignition and won't turn off
Paul Kizer
03-01-2015 01:40 AM
7th Gen ('06-'07): Key getting stuck in ignition
L_Snel
01-02-2015 09:37 AM
MsFiasco
06-22-2011 12:14 PM
