changing interior lights
Old Feb 2, 2009 | 05:21 PM
Default changing interior lights
Okay, for the life of me I can not figure this one out. And I'm sure it's so simple, but I don't want to go breaking anything.
I bought LEDs for the interior lights, 2 for the floor and a dome light. I can not get the Dome cover off at all, and I have no idea how to take the 2 floor lights (under the dash) out of their socket. I twist and pull but it doesn't budge.
Makes me feel a little stupid about the whole procedure lol
Old Feb 2, 2009 | 05:46 PM
Enzo354's Avatar
STILL SLOW
Default RE: changing interior lights
The bottom ones should just pull right out, might take some force. The dome is alot harder. Sometimes you have to go in from the top of the headliner and press down on it.
Old Feb 2, 2009 | 05:51 PM
that's the thing, I was pulling on them as hard as i could, to the point that the whole object was moving, and i didn't like that.
Old Feb 2, 2009 | 05:54 PM
Enzo354's Avatar
STILL SLOW
I cant think of why they would be wedged in so much. Mine were burnt out and i didnt like the look of lights down there, so I just left it dark.
Old Feb 2, 2009 | 06:21 PM
Okay, i got those floor bulbs out. You were right, just yank hard and wiggle lol.
Now about this dome light... I'm really struggling on this one. Anybody have any tips? I feel i'm pulling my whole headliner off and it's not budging
Old Feb 2, 2009 | 06:35 PM
sonin66's Avatar
i thought the dome light covers just pop right off, try using a flathead on it
Old Feb 2, 2009 | 08:13 PM
Okay. When trying to pry the dome light off, should I force thescrewdriver around the dark plastic part or the clear? I wish I could just see what it looked like off so I could determine how it is actually on there and have it make sense to me. Instead of just yanking on stuff.
Old Feb 3, 2009 | 08:52 PM
bowtietech's Avatar
Hope this helps......
[hr]
Dome Lamp Replacement (Impala and Monte Carlo) [/align]
Removal Procedure
[ol]
Remove the dome lamp lens from the dome lamp bezel using a small flat bladed tool as a lever on the right side of the dome lamp lens.
Remove the dome lamp lens from the dome lamp bezel.
Remove the dome lamp bulb.
Remove the dome lamp bezel from the headliner using a small flat bladed tool to depress the tab retainers.
Remove the dome lamp from the headliner.
Remove the dome lamp socket from the dome lamp bezel by squeezing each terminal and pressing out.
Remove the dome lamp socket from the dome lamp bezel.
Remove the dome lamp electrical wiring from back side of the dome lamp bezel.
Remove the dome lamp from the vehicle. [/ol]
Installation Procedure
[ol]
Install the dome lamp socket to the dome lamp bezel by squeezing each terminal and pressing into place until fully seated.
Install the dome lamp electrical wiring to back side of the dome lamp bezel.
Important:The dome lamp bezel will not have a tight fit to the headliner until the dome lamp lens is installed.
Install the dome lamp bezel to the headliner pressing into place until the tab retainers are fully seated.
Install the dome lamp bulb.
Install the dome lamp lens to the dome lamp bezel.
[/ol]
Old Feb 3, 2009 | 08:59 PM
MC730's Avatar
bow tie hit the nail on the head with that design, but to answer your question before you force the screwdriver around the clear part. just follow the diagram and to change the bulb it should be very straight forward i believe that the diagram shows something about wiring, i didnt have to deal with any wiring when changing the dome light.
Old Feb 3, 2009 | 09:01 PM
MC730's Avatar
and btw bowtie that is one good looking monte and it must flyyyy with that exhaust and intake awesommee
