2002 monte carlo ls
Old Aug 25, 2020 | 02:35 PM
Originally Posted by Tracy Cottrell
no it wont come on at all
If you get no air out of the blower at all, then that may be easier / cheaper than a AC issue. Id start by checking fuses related to HVAC, followed by getting out a multimeter to see where you're losing signal (ie is the HVAC controller working, is there power at the fan motor, etc).
yes the car still moves but kinda like stutters then kicks in slowly and its fine after that
To driver 3's point- you noted the service was done - how recently? Was it fluid + filter or just fluid?
I'd also agree with driver 3's point that this service is unfortunately a fairly common one for places to sell and not do. Many people don't know what / how to check, and after another oil change worth of miles, there's no way to prove it one way or the other anymore. Certainly worth a look to pull out the trans dip stick and see what it looks like.
I'd still honestly prepare for the worst, especially at that mileage. There are several possible issues that can cause that problem - most of which would require at least partial trans disassembly. Of course no one would pull apart a trans with that much mileage and not rebuild the whole thing.
Old Aug 25, 2020 | 06:48 PM
cariece02@yahoo.com's Avatar
Default Stuttering when taking off.
1st issue is my ac just stopped working 2 nd issue is that the blower only worked on speed 5,and last my transmission slips in 1st gear I call it stuttering it only does it in when taking off but not all the time,it has the 3400 motor
Tracy
check your coils first this can cause that and also the Cadillac converter.
if the check engine light is on in your car take it by O’Reilly‘s or a AutoZone and they can give you the code this will help a lot.
if it is the car they are very easy and less expensive to fix. (you have 3 of them but only one may be bad)
I have had the same problem with my blower staying on five and I did replace the blower in the car and I have also replaced the panel where all your switches are and it worked for a while but now it’s doing the same thing again.
however if I turn it to five and turn it back just a little bit it will start blowing correctly
Hope this helps you a little bit
batmans_mc
Sep 13, 2020 08:23 AM
Huckster
Aug 14, 2013 11:39 AM
HIxArsenaL
Feb 16, 2013 09:32 PM
Skilletan
Jan 29, 2013 05:31 PM
Jsim465
Mar 15, 2012 08:36 PM
