2001 rear defrost question
Rear defrost is not working took it to the shop. They said its a triangular shaped module, cost somewhere around 20 dollars, but will cost over 300.00 due to labor. They would not tell me much more than that. Well 300.00 is a bit steep so want to fix it myself. Can someone tell me location and what to look for. Thank You.
I think we're going to try soldering.
Here's the best thing to do with defroster items:
1 - Check the tabs on the glass on the back, ensure they are still soldiered on (there have been some cases where they "fell off".
2 - Check the circuit braker (you have to pop the fuse block out as the thing is on the back). Here's a write up about it:
https://montecarloforum.com/forum/si...breaker-33233/
3 - Behind the rear passenger side quarter panel lives a defroster/radio antenna module. This is known to go bad. I never had to replace one, but I priced it with a dealer, it's about $20.
I just got caught up (due to slow Internet connections). If you go with soldiering, BE CAREFUL! Do NOT solder when the car and glass are cold, otherwise, you risk cracking.
I've rear of people who have used the repair kits from the auto parts stores successfully (and I believe those are all adhesive based, no hot products or tools required).
Spent (wasted) $27 on the two permatex attempts while the frost fighter was about $35 with shipping. 24 hours curing was recommended with the permatex while the frost fighter took only two hours.
If you DO try soldering place a wet towel on the outside of the window to help dissipate the heat to reduce the chance of cracking the glass. Its also very awkward to hold the tab in place and solder at the same time.
Unless you are really good at soldering I wouldn't risk trying it yourself. I would wait until the outside temperature is in the 70's or so. Also you should use a variable heat soldering iron with a low setting. I think you should use a heat sink to absorb the heat too but i don't know how you would.
