2001 MC SS Driver Window Problems
Old 08-24-2010 | 04:32 AM
firedude7048's Avatar
Default 2001 MC SS Driver Window Problems
Heres my problem, driver door window goes down but not up. Replaced Switch, motor, accessory power relay. Still wont go up. Checked Wiring and had electrician check it with his tester got power to everything. What should i do now.
Old 08-24-2010 | 10:53 AM
Sparky-88's Avatar
Sounds like a bad switch, but you already replaced that. However I'll add that I recently I replaced 4 window switches on an old Jag and 1 of the 4 was bad right out of the box. If you have a multimeter, you might want to test the switch. See if it's sending power to the window motor during switch up operation. That way you can rule out a problem with the switch before throwing more $ at it.
Old 08-24-2010 | 11:26 AM
00SSsupercharged's Avatar
I had to change my switch three times. First one it just burned out, second one it just wouldn't want to go up, finally I went to get the third one and it just happen to work.
Old 08-26-2010 | 03:44 AM
lucian*91's Avatar
can you jump the switch going power to motor to make it go up? by leaving the switch plugged in, touch the back of it with a jumper wire. power to motor..
do you understand or am i being confusing?
Old 08-29-2010 | 09:45 PM
spiknek's Avatar
Smile
hey man dont waste your time or money buying the switch on line to save a few dollars.
I did that and after four of them!!!! I gave up and went to dealer and had to buy it from them.
the aftermarket ones burn. they work until you try to put the window up
there is a component missing within them (aftermarket ones) or find it at a junk yard but it needs to be the factory original.
Good Luck.
Spiknek....
Old 09-01-2010 | 09:19 PM
HPNOTIQracing's Avatar
i have sortra the same problem. mine goes down but when i roll it up it stops after a few inches and i have to go back out to the car a few minutes later and get another few inches.
nemii
12-10-2017 09:30 AM
gtpshawty
09-13-2013 04:29 AM
USMC8825
10-02-2009 03:09 PM
cimber
08-19-2008 09:52 PM
morgandhash
12-01-2007 12:56 AM
