2001 MC SS Driver Window Problems
Old Aug 24, 2010 | 03:32 AM
firedude7048's Avatar
Default 2001 MC SS Driver Window Problems
Heres my problem, driver door window goes down but not up. Replaced Switch, motor, accessory power relay. Still wont go up. Checked Wiring and had electrician check it with his tester got power to everything. What should i do now.
Old Aug 24, 2010 | 09:53 AM
Sparky-88's Avatar
Sounds like a bad switch, but you already replaced that. However I'll add that I recently I replaced 4 window switches on an old Jag and 1 of the 4 was bad right out of the box. If you have a multimeter, you might want to test the switch. See if it's sending power to the window motor during switch up operation. That way you can rule out a problem with the switch before throwing more $ at it.
Old Aug 24, 2010 | 10:26 AM
00SSsupercharged's Avatar
I had to change my switch three times. First one it just burned out, second one it just wouldn't want to go up, finally I went to get the third one and it just happen to work.
Old Aug 26, 2010 | 02:44 AM
lucian*91's Avatar
can you jump the switch going power to motor to make it go up? by leaving the switch plugged in, touch the back of it with a jumper wire. power to motor..
do you understand or am i being confusing?
Old Aug 29, 2010 | 08:45 PM
spiknek's Avatar
Smile
hey man dont waste your time or money buying the switch on line to save a few dollars.
I did that and after four of them!!!! I gave up and went to dealer and had to buy it from them.
the aftermarket ones burn. they work until you try to put the window up
there is a component missing within them (aftermarket ones) or find it at a junk yard but it needs to be the factory original.
Good Luck.
Spiknek....
Old Sep 1, 2010 | 08:19 PM
HPNOTIQracing's Avatar
i have sortra the same problem. mine goes down but when i roll it up it stops after a few inches and i have to go back out to the car a few minutes later and get another few inches.
nemii
Dec 10, 2017 08:30 AM
gtpshawty
Sep 13, 2013 03:29 AM
USMC8825
Oct 2, 2009 02:09 PM
cimber
Aug 19, 2008 08:52 PM
morgandhash
Nov 30, 2007 11:56 PM
