2000 monte wont start
i just replaced the motor in my 2000 monte ss. I cant get it to turn over. starter is good. battery has power and terminals are clean. fuel pump doesnt kick on. radio is also saying "cal err". any help would be appreciated.
Welcome to the MCF.
What did you replace it with ? A rebuilt engine ? a used engine ? Please post what your replacement engine was ?
Did it run before you put it in your Monte ?
Where did you get it ? How many miles were on it ?
Please post as much information about your replacement engine to help our member's help you
![Thumbsup](https://montecarloforum.com/forum/images/smilies/thumbsup.gif)
3800 series motor from a 2000 buick. motor has 70,000 on it. motor is in good shape. turns over, has compression, replaced lower intake manifold gasket, water pump, plug wires, oil pin, etc. the car has sat for a year. charged the battery and holds a charge. everything lights up just no cranking.
When you turn the key to the ON position you should hear the fuel pump prime. If you're not the first thing I'd do would be to double check all my wiring to make sure I didn't accidently forget to hook or tighten something up. Since the car sat for so long you may also need to do a security relearn in order to get it to crank over. Turn the key to the ON position and leave it there for 11 minutes, then turn it to the OFF position for 30 seconds. Repeat this 3 times then try to start the vehicle.
Did you swap a BCM or PCM in this process??? CAL ERR on the radio is sometimes related to a problem with the radio and BCM not communicating properly (it may require a GM Tech II to re-program).
If you swapped the PCM (which you should not have to do so long as the motor going into the car is the same as the one that came out), you may need to do a PCM relearn. If the PCM has an issue, it will prevent either the pump form engaging or the injectors from releasing fuel (I can't remember which).
Sorry to read that you are still having problems ![Frown](https://montecarloforum.com/forum/images/smilies/frown.gif)
Check your starter connections, and make sure there is power to it and that your solenoid is not bad ? or that your starter is not binding & preventing it from turning (?)
Check the below link on your other questions, and also check our MCF search engine & search for problems that may have already been answers by member's...Good Luck 4-Sure![Thumbsup](https://montecarloforum.com/forum/images/smilies/thumbsup.gif)
https://montecarloforum.com/forum/ge...ocation-36805/
Click
GM Tech-2
<TABLE id=ptable><TBODY><TR><TD class=img rowSpan=6>
</TD><TD class=text>Product NO.: PRT0005 </TD></TR><TR><TD class=text>Product Name:GM Tech-2,Vetronix GM Tech-2 Scanner</TD></TR><TR><TD class=text>Weight: 12.0 KG</TD></TR><TR><TD class=text>Price: $590 </TD></TR><TR><TD class=text>Shipping: Calculated at </TD></TR></TBODY></TABLE>
![Roll Eyes (Sarcastic)](https://montecarloforum.com/forum/images/smilies/rolleyes.gif)
GM Tech-2
![](http://www.obdiiscanner.com/images/mid/GM%20Tech-2.jpg)
PDF]
Tech 2 User's Guide
File Format: PDF/Adobe Acrobat - Quick View
The Tech 2 User's Guide provides a comprehensive overview of the Tech 2 scan tool. Everything ... Before making a call to the Customer Support Center or GM Dealer Equipment, be sure to have the ..... (For information on this program, refer ...
Tech 2 User's Guide
Check your fuses. The one for the fuel pump is located in the upper underhood fuse panel and labeled 'F/PMP RLY'. The one for the ignition is located in the lower underhood fuse panel and labeled 'IGN SW'. Even if the fuses look good check them for continuity. You may also want to check the ignition and fuel pump relays. You can swap out like relays as a test.
ive checked the fuses and the starter. ive gone through all the "old school" methods of checking. when i pulled the fuse for the bcm none of the alarms went off. the only two that come up when the fuse was placed back inare low fuel and tcs. theres fuel in it and im sure the tcs is in working order. i just dont want to go to the dealer. the dealer and i have a really bad past hence why i put a new motor in when i shouldn't have had to do it. the pass lock is good. the battery is good. ive gone through it more than 5 times. my radio still flashes a "cal err" and the feeling im getting is if i swap out the bcm i still need to program it.
