2000 monte no dash or tail lights
Just to confirm:
- No dash is meaning no instrument panel back lighting, no radio back lighting and no back lighting on the door lock and window switches?
- Why did you change the turn signal/multi-function switch? Was it in hopes it was related to this issue?
- You said no tail lights, but the hazards work. What about brake and turn signal lights? Or are the only tail light issues when they should be active at night? What about the front lights?
So 1st yes no backlights or radio. Lights brake lights are working flasher relay for turn signal clicks hyper fast headlights work not sure why my brother changed multifunction switch
If the flasher module is clicking really fast, it is either a turn signal bulb is burned our or the flasher module is bad. Some of the bulbs in the back have dual filament and are actually like 2 bulbs in one. It is possible for one filament to be burned out. Have you verified all bulbs are in working condition and not burned out? Still not sure why all the dash lights would not work. You might need to get some schematics and do some testings on this....
6th Gen ('00-'05): Tail Lights and Dash Lights are Out
Brandon Johnson
May 22, 2019 12:15 PM
