1999 Monte-No Brake, turn, hazard lights
Old Oct 12, 2012 | 11:55 AM
mykels1's Avatar
Default 1999 Monte-No Brake, turn, hazard lights
Can anyone steer me in the right direction? My 99 Monte has no brake, hazard or turn signals. I checked the fuses and all are ok. Is there a relay for this or could it be the flasher? If it is the flasher, where is it located?
Old Oct 20, 2012 | 11:46 AM
mykels1's Avatar
The problem ended up being a broken hazard switch. For some reason the broken switch was not allowing power to go to the brake lights or turn signals.
Old Nov 26, 2013 | 05:52 PM
johns811's Avatar
Hi, we just picked up our 1999 z34 monte from the shop from a rusted brake line repair. We have no turn signals, brake lights or emergency flashers. I went to try the flashers and the little plastic flasher switch looks like it is cracked and came right out from the top of the column. However I set it back in place and the switch seems like it is clicking on and off. Is it possible the shop or the tow truck drive busted this and broke my car? How difficult was it to replace the hazard switch. I'm thinking the shop broke this and should be responsible. It was working perfectly before we had it towed there.
Old Nov 26, 2013 | 06:05 PM
l67ss's Avatar
Could be the cause. Dont know why theyed be around the column with a bl change tho......
Old Nov 26, 2013 | 06:49 PM
johns811's Avatar
I thought the tow driver must have pulled out on the switch. The plastic is cracked but the switch internally sounds to be working. I don't care about the plastic but I need to get the lights working.
TheConcreteGuy
Feb 22, 2015 06:12 PM
monteriderLS
Apr 1, 2013 08:57 AM
heartbeat
Jan 14, 2012 10:47 PM
shad420w
Apr 7, 2011 10:31 AM
kennyjohn
Nov 23, 2010 03:22 AM
