1999 Monte Carlo 3.1
Old May 20, 2011 | 06:11 PM
justhunt87's Avatar
Default 1999 Monte Carlo 3.1
I just bought this car and i got it for 400.00. And it has very little power and just kinda putts around. Any Ideas???
Thanks Dylan
Old May 22, 2011 | 06:57 PM
skylark65's Avatar
wow, never thought i'd see another $400 special on here!
i would start with a fuel filter, and if it's throwing any "check engine" or "service engine soon" lights bring the car to a local auto parts store and have them plug a scanner into it. first guess if it's got a light on is the car could be in "limp home mode", which could be caused by a bad O2 sensor among other things.
Old May 31, 2011 | 07:10 PM
7498MonteCarlo's Avatar
Photobucket
Monte Of The Month -- August 2010
Where is the fuel filter located in a G5 MC?
Old Jun 1, 2011 | 09:18 AM
jimmyfloyd's Avatar
between the gas tank and the fuel rail...
I believe it is just behind the passenger or driver's side front wheel under the car, but I could be confusing it with one of the other cars I had. Been a while.
Appear that it might be near the back wheel instead. here is a diagram. Fuel Filter is #11. I believe that is the rear of the car.
http://www.compnine.com/index.php?u=...03&grouptype=B
Old Jun 1, 2011 | 09:49 AM
Photobucket
I should probably replace mine. It's probably never been replaced before. =X
Thanks for the diagram!
Old Jun 1, 2011 | 10:15 AM
It could be a LOT of stuff.... Odds are you're dealing with a high miles car in need of some TLC. Also, is this 3.1 the 3100 model (I've worked on a few 3100's in the mid-90's Grand Ams, they are pretty easy). Here's a basic list of "to-do's" (some may have already been mentioned):
- Change Plugs and Wires (do NOT use Bosch Plugs, they such, but Bosch wires have been good to me). AC Delco stuff is the best.
- Change Air and Fuel Filter.
- If this is a 3100, you may want to remove the EGR and ensure it has no blockage in the tube leading into the upper intake.
- Fresh Oil change
- Inspect the belt, if it's old or appears worn out, replace it.
- Flush the coolant
I can tell you, treated right a 3100 will last a long time (I am still driving a '94 Grand Am with a 3100, biggest job I did on it was head gaskets at 180K and it now has about 210K on it, runs like NEW).
zzapultimate
Mar 8, 2009 07:41 PM
radiantdragoon87
Oct 17, 2008 12:46 PM
Mr. Fool
Apr 9, 2007 02:27 PM
xxMoNtEdRiVeRxx
Sep 2, 2006 08:44 PM
