1999 Master power window switch connector.
Hello everyone,
I was hit in my driver's door and the the body shop that repaired it was lacking in skills. The window kept coming out of it's track and I took it back to them 4 or 5 times. The forth time the motor failed and the fifth the switch. The regulator w/motor they replaced it with was from the wreckers and now it has failed. Since these repairs were a couple years ago now I am doing it myself. In doing so I see that part of the side of my switch casing is missing and the connector to the switch is half gone too, I mean they put shrink tubing on the wires and shoved them into place. My problem is that when I took it off I didn't notice the connector was destroyed or where the wires go. I ordered a new switch and connector but cannot find any resources to what wire goes to which pin.
Does anyone have the knowledge or the service manual to the 99 Monte Carlo and does it show wire color to pin placement in the connector to the driver's power window switch? Chilton's is too basic and the parts guy at the dealer has nothing.
Many thanks!!!
Many thanks!!!
Well the forum is nice but it is slow. I ended up going to a wrecking yard before my new switch and connector arrived. Since most of the connector was destroyed by Roth Miller body shop, I didn't realize there were letters on the connector. I took a picture of the connector with the wires in place. I have since seen a diagram online
which gives the color of wires with the designated connector letters. Thanks...
If anyone needs this it is as follows:
A:brown
B:Tan
C:empty
D:Grey
E:dark Blue
F:light Blue
G:Black
H:yellow
A:brown
B:Tan
C:empty
D:Grey
E:dark Blue
F:light Blue
G:Black
H:yellow
qzack1
08-28-2011 01:50 PM
