1998 MC ABS wiring
Old Jul 30, 2013 | 04:41 PM
skramy's Avatar
Default 1998 MC ABS wiring
I have a broken wire on my Antilock Brake System. One end of the wire plugs into the speed sensor by the wheel. The other end of the wire goes up, then thru the fenderwell where there is another connector near the firewall.
Hoping to repair the wiring. How do I remove the upper end? Do I remove the wire assembly/grommet thru the hole from the outer side of the wheelwell in, or from the inner side of the wheelwell out? Removed a horseshoe clip from the wheel side of the wheelwell but haven't tried to remove wire assy yet.
SteveS
cool77
Jul 4, 2016 07:36 PM
lonerider
Dec 22, 2014 07:20 PM
pipefighter
Jul 2, 2010 12:44 PM
lateralex426
Feb 5, 2007 08:57 PM
redneckmc
Oct 1, 2004 09:39 AM
