1995 Z34 Died, Won't Start
Old Jun 15, 2008 | 06:00 PM
Dizzy412's Avatar
Default 1995 Z34 Died, Won't Start
The other day I was cruising down the highway when I noticed several subtle "pulses" from the engine. A few moments later the car died. The motor will turn over just fine, but the car will not start. I took the fuel line loose from the filter on the gas tank side and turned on the key. I got a weak spurt of gas and that was it. I have replaced the fuel pump. I still have the same problem. Anyone out there that can point me in the right direction on this problem, I would appreciate. I really can't afford to go to a mechanic, nor can I afford to replace random parts until the car starts. Could it be a bad replacement pump, a relay, the computer? Thanks in advance.
Old Jun 15, 2008 | 09:00 PM
rysZ34's Avatar
Default RE: 1995 Z34 Died, Won't Start
Make sure your fuel filter isn't clogged. I would change that too.
Bob Partridge
Sep 23, 2015 02:00 PM
chrismm
May 16, 2014 08:08 AM
hacknfrack
Aug 3, 2013 10:50 PM
sickofmycar
14
Jun 10, 2011 03:37 PM
Harleyldraper
Sep 9, 2010 06:53 PM
