1995 Z34 Died, Won't Start
The other day I was cruising down the highway when I noticed several subtle "pulses" from the engine. A few moments later the car died. The motor will turn over just fine, but the car will not start. I took the fuel line loose from the filter on the gas tank side and turned on the key. I got a weak spurt of gas and that was it. I have replaced the fuel pump. I still have the same problem. Anyone out there that can point me in the right direction on this problem, I would appreciate. I really can't afford to go to a mechanic, nor can I afford to replace random parts until the car starts. Could it be a bad replacement pump, a relay, the computer? Thanks in advance.
RE: 1995 Z34 Died, Won't Start
Make sure your fuel filter isn't clogged. I would change that too.
