1995 Monte Carlo won't turn over
Old Aug 3, 2014 | 10:07 PM
95carlomonte's Avatar
Default 1995 Monte Carlo won't turn over
I have been fixing my monte for about 2 months now. It has been setting in my garage up on jack stands and the neg. Battery disconnected. When i put it there it ran fine. I've done many things including replacing a turn signal switch, which required me to take out the 2 airbag fuses on the passenger side dash.
That is my fist guess of the problem. So what I am wondering is if those 2 fuses would cause the car to not start?? The reason I have not put them back in is that it is parked in my garage so that I can't open the door to get to the fuses Another possibility is the new radio I put in it. I've heard of peoples cars not starting after putting in a new radio. Things like the rf signals that it puts out messes with the VATS or passkey system (my new radio does have a remote)
The last possibility is the VATS and passlock. .........the car will not turn over at all. It has a brand new battery and I also tryed jumping it. I can hear the fuel pump come on when I turn the key.
When I turn the key to start it there's nothing no clicking no starter sound at all. But when I let the key back it makes a little noise. I pinpointed the noise to being right by the fuse box under the hood on the drivers side.
So what I want to know is is if I should take it down and push it to get the fuses in, or if its something else.
Thanks for any help!
Old Aug 4, 2014 | 09:23 AM
Lightbulb Welcome to the MCF
I suggest checking all your fuses to make sure they are good. > Good Luck <
Old Aug 4, 2014 | 10:25 AM
nitehawkjcb's Avatar
Sounds like a VATS issue. Check the ohms of the chip in your key. You can wire in a resistor or two under the dash to bypass it, otherwise you're gonna need a new ignition switch (if that is in fact the issue)
IDreamOfMySeventySeven
Aug 21, 2015 02:27 PM
ladytee27
Jun 6, 2015 10:46 PM
Gerald W Steingruber
May 25, 2015 06:42 PM
bfenty
Apr 5, 2014 02:43 PM
Cschlue
May 10, 2010 09:06 AM
