1987 Monte Carlo Wont go into gear
Old Oct 21, 2019 | 03:38 PM
justinb628's Avatar
Default 1987 Monte Carlo Wont go into gear
Hello, I have a 1987 monte carlo ss automatic and it seems to have a third party shift called hurst and for some reason the car wont go out of park. Please help.
Old Oct 22, 2019 | 07:25 AM
Jeffs02rwdSS's Avatar
Kinda hard to tell which style Hurst shifter it is. Most have a reverse lockout. On mine I have to pull up on a lock to disengage which I don't see in your picture. A few questions. Did it work prior ? Is it still connected to the factory system that also turns the steering column at the same time ? If you disconnect the cable off the shifter will it shift the transmission ? Kinda hard to see but my lockout is right below the top handle
Old Oct 22, 2019 | 08:15 AM
justinb628's Avatar
Default Should I buy a new shifter box?
There is no release button on the hurst shifter
Old Oct 22, 2019 | 09:17 AM
Hurst is a premier shifter they have been around for years, Mine were with manual Transmissions.
One thing you could try it look up Hurst shifter on google and select videos and there might be exactly the one you need on there.
Old Oct 22, 2019 | 06:29 PM
As I stated earlier there are different versions. Mine is a V matic and as shown has one. Perhaps yours is supposed to push down or over to release the lock. Driver#3 had a good idea and try a Google search, just need to figure out what style shifter it is. Good luck
mr markuSS
Aug 1, 2015 04:14 PM
Tobian46
Feb 10, 2015 08:59 PM
mikehuichen
Jul 8, 2011 06:45 PM
White04monte
Mar 25, 2010 11:19 PM
Monte SSV
Feb 28, 2009 07:56 PM
