1970 monte wheel hop issue
Old 12-24-2013, 11:40 PM
19monte70's Avatar
Default 1970 monte wheel hop issue
Hey guys I am having problems with wheel hop during launches and burnouts.
I Have the rear end of the car raised 2 inched higher than stock and like the look so I don't want to change that. The rear suspension bushings have not been replaced, will that help? One option I have seen it lift bars from umi, have any of you used these? Any help with this issue would be appreciated.
Seth
Old 12-25-2013, 03:49 AM
A rear sway bar would help out a lot
Old 12-25-2013, 08:18 AM
You could change it over to a 4 bar system that would solve all your traction wheel hop issues!
How'd you raise the rear of the car? If your running air shocks...That's a Major part of the problem.
You'd be better off with a coil over setup. also. Or convert it over to leaf spring setup using a ford 9" rearend .
Old 12-25-2013, 09:09 AM
19monte70's Avatar
I lifted the rear with new coil springs, they were station wagon springs for a Chevelle. I don't have a huge budget so a new rear end or major modifications are out.
Seth
Old 12-25-2013, 10:02 PM
The U.M.I peices are nice and not too outragous on price. combined with polyurthane bushings on the rear-end housing, that should take care of it.
1984SS2002
04-18-2015 01:40 PM
Chainsaw
12-22-2010 09:05 PM
04MonteLS
11-08-2005 02:56 PM
Patrick
03-21-2005 10:50 PM
Quick Reply: 1970 monte wheel hop issue
