06 Monte Carlo LT Loose chrome tip
Old 05-17-2011 | 11:05 PM
qitupx's Avatar
Default 06 Monte Carlo LT Loose chrome tip
Hello!
First of all, I just bought this car a few months ago, first Monte Carlo ever--almost bought a Mustang buttttt I decided to go with this. The title says this is an Enthusiast community--I'm not one...yet at least. Anyways
Today I was backing out of the Garage and I noticed that the car was making an odd noise when I was reversing out; went to the back and noticed that the right chrome tip is a bit loose. It's a bit rainy out today and decided before I get wet to ask you guys if the Chrome tips are screwed on, welded on, etc and if there is any easy way for me to fix it. Thanks!
Old 05-18-2011 | 12:21 AM
myfirstbowtie's Avatar
I've got an '06 Monte LT also, and they do not come from the factory with chrome tips. The person who had the car before you must have added them on. The only way for you to tell how they're attached is to stick your head under the back bumper and look.
If the ones on your car are bolted or screwed on, you can just tighten it up yourself, or you can take your car to a muffler shop and have them welded on so you don't have to worry about them coming loose again. They shouldn't charge you more than a few bucks to do that.
Old 05-18-2011 | 12:26 AM
Welcome to the site and if your here your on your way to being an enthusiast. You will have to look at the tip on your car because we don't know if it's stock or been added by a previous owner. Check it out and let us know.
Old 05-18-2011 | 02:32 AM
qitupx's Avatar
I thought it was stock for some reason. But yeah, it is welded on. I guess I'll take it to the muffler shop and have it welded back on. It does appear to have a lot of rust inside and that is what caused it to break.
Old 05-18-2011 | 06:04 AM
It probably is a cheap-o non-stainless steel tip from your local auto store.
It might be beneficial to purchase your own high quality tip and have the shop put that one on.
mmonh
06-25-2011 10:05 AM
luke2seagull
04-03-2008 08:44 PM
1999Monte
06-17-2007 08:12 AM
shmedley
03-07-2007 07:21 PM
04MonteSS
12-22-2006 11:18 PM
Quick Reply: 06 Monte Carlo LT Loose chrome tip
