need help
Old May 18, 2011 | 07:15 AM
lilgeo3746's Avatar
Default need help
how do you set the timing on a Monte Carlo 3.4L
Old May 18, 2011 | 07:17 AM
lilgeo3746's Avatar
how do you set the timing on a Monte Carlo 3.4L 1996
Old May 18, 2011 | 07:19 AM
augi's Avatar
I would take the belt off and align all of the teeth on top dead center and replace the belt... now that's a direct answer to the qhestion, but I have a feeling you had a more specific problem... we need more details... what's the car doing and such?
augi's Avatar
By the way, welcome to the forum.
Old May 18, 2011 | 11:13 AM
lilgeo3746's Avatar
ok i just change the head gaskets,intake ,etc put everything back together. i just cant get the timing right. its a 1996 Monte Carlo with a 3.4 and replace the timing belt too.
Old May 18, 2011 | 11:21 AM
augi's Avatar
Yeah it's pita but you can line it up. Just make sure eveyrthing is dead on... you may have to advance or retard a tooth before releasing the tensioner.
Old May 18, 2011 | 11:40 AM
lilgeo3746's Avatar
let me give you a little more infor. would the timing off. would that stop me from getting spark, im not getting any fire,getting gas but no fire.
Old May 18, 2011 | 04:47 PM
lilgeo3746's Avatar
Im not getting any fire from the core pack,got a new 1 still no power.what can i do
Old May 19, 2011 | 05:58 AM
augi's Avatar
Sounds to me like the ignition control module
Or... scarily the pcm... but im hoping for you its the primary
You can remove it and take it to a parts store and have it tested
Just tell them to test it a couple of times
Old May 19, 2011 | 07:29 AM
03SSLE's Avatar
Is your security light on or flashing? Just a guess, but maybe after having the battery disconnected during the engine repair the security system needs to relearn? Turn the ignition switch to the "on" position, leave it there for 10 minutes then turn it off. Now try to start the car. If that doesn't work try it again but do the procedure 3 times in a row for a total of 30 minutes then try to start the car. Like I said, just a guess on my part...good luck.
Kostya Valerio
15
Jun 14, 2015 09:52 PM
jaydflash
Aug 29, 2014 03:38 AM
00SSsupercharged
Apr 29, 2009 09:45 PM
zk6216
Mar 11, 2008 11:19 PM
mickey
Aug 23, 2006 05:31 PM
